qc91's avatar
qc91
Help with Air Horns
Hi, Need help we have a 2007 National RV Dolphin Class A Motorhome that we purchase we notice that it has Air Horns on the Roof but we can’t see to find out where the switch is for them there is a name of “Seaworld” on the back for the Horns I have attached some photos any help would be greatly appreciated
  • Hi, Yes I do see wires and looking online the SEAWORD they make Air Horns for Boats we do have a Gas RV
    Thanks
  • OK,,since you have other horns, the ones on the roof may be real or fake. If they are air horns there will be no wires attached, just a small air tube. There also should be a small air tank somewhere on the coach. Those would be after market so if they're real, the switch could be anywhere. Only way to find it is to start at the horns and work backwards....question you have to ask yourself is; "Is it worth it..":h...Dennis
    BTW..Seaworld makes a marine air horn if that helps..D
  • There might be a switch that says City/Highway to change between the horns. When I installed mine that is what I done and have seen it on other MH's. JMO
  • Go on roof see if they have wires running to them. I think thy are phony electric horns that look like air horns. If so they are very cheap and I have never seen them work. If a horn honks when you push steering wheel then the ones on top are probably the fake electric type. Yours is a gas rig correct?
  • Hi, Yes we have Tried the Steering wheel but it only blows the Ford Horn
    Thanks
  • Have you tried the horn ring on the steering wheel?...not trying to be a SA but unless you have electric horns too, that would be where to find it..whether they work or not is another subject.....Dennis
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
