OK, we have a sensar III Antenna on our 2015 Montana. Stupid question but we want to know once and for all. One side is wear the cable go in. Other side is flat and has winegard on it. Then we hav...
The flat side with Winegard is the front and where you need to aim. You should invest in the Wingman add on and then reception for many channels will improve and there will be no doubt which way to point. Regardless of what you do, OTA tv reception is and always has been hit or miss.
I can tell you that after trying several, you have about the best there is. Adding the Wingman will help as will the Sensar Pro control box. But again, hit or miss.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
