OK, we have a sensar III Antenna on our 2015 Montana. Stupid question but we want to know once and for all. One side is wear the cable go in. Other side is flat and has winegard on it. Then we hav...
Ok if you have a SENSAR III without teh Wingman then the pattern is a figure 8, Does not matter if the front or the back is toward the station it works either way. There is more to this but Ill leave it off now.
IF you add the WINGMAN then the WINGMAN points to the transmission tower, By the way I suggest teh wingman.
Another suggestion is the SENSAR PRO. adds amplification and a host of other features. it will also answer your question for you.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
