OK, we have a sensar III Antenna on our 2015 Montana. Stupid question but we want to know once and for all. One side is wear the cable go in. Other side is flat and has winegard on it. Then we hav...
Phoenix is one area where the signal strength is so strong you can actually have the signal swamped just by having the Batwing in the air. You will want to ensure that the Sensar Pro is set to 10 or less (10 is zero additional gain, less attenuates the signal and more amplifies the signal). When we were in that area we got the best reception with the antenna stowed for travel to help reduce the strength of the broadcast signal.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
