TCI's avatar
TCI
Help with Antenna
OK, we have a sensar III Antenna on our 2015 Montana. Stupid question but we want to know once and for all. One side is wear the cable go in. Other side is flat and has winegard on it. Then we have the wings. One is on the W side of Winegard and the other is on the D side. If I want to point my antenna North, which side is the actual pointer. The wings, the back or the flat front with Winegard on it? Thanks for your patients. We have been using these things for years and always fight with it.
  • The flat side with Winegard is the front and where you need to aim. You should invest in the Wingman add on and then reception for many channels will improve and there will be no doubt which way to point. Regardless of what you do, OTA tv reception is and always has been hit or miss.
    I can tell you that after trying several, you have about the best there is. Adding the Wingman will help as will the Sensar Pro control box. But again, hit or miss.
  • Going by this picture, Antenna, the short stubby antenna elements should be aligned at a right angle to the TV transmitting antenna.
    Put another way, you'll be pointing the end of the structure that's supporting those short antenna segments (that are parallel to the main wings) towards the transmitting tower.
    Usually, towns and cities have all the transmitters for different TV networks all on the same or nearby hills so generally if you're within 25 miles of the towers you only need to point in one direction. I do have to occasionally turn the antenna to improve the signal for a certain network. Where I am in Sioux Falls, I don't even get ABC. Note that TREES play havoc with TV signals (and Wifi signals).
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
