NinerBikes
Aug 31, 2014Explorer
smkettner wrote:
Get an IOTA or Progressive Dynamics replacement converter. Boondocker will short charge the battery to 70/75% and drop voltage for absorption vs the others that hold voltage up for a few more hours. Since you boondock a lot you will wish you had just replaced the WFCO long before it failed.
This, and if you boon dock a lot, I'd opt for the 14.8 volt Iota version over the 14.4V PD version. Hope you have a Honda EU2000i generator or larger for the 45 amp version. In either case, get the pendant that comes with it, and use the boost feature religiously to keep your battery charge up.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
