sjturbo
Sep 01, 2014Explorer
NinerBikes,thanks again for the inputs. You have given me other information on my other post "am I shortening my battery life". On that subject you indicated a Top Charge of 14.5 for my two Crown CR235's in series. For additional information I will be using four Crown CR235 (470 Ah total, Series/Parallel). If I were to place the Iota as a stand alone I would no longer have the use of the WFCO 8955 Power Center as a 12v fuse center, is that correct? I hope this helps clarify my situation.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
