Thunder_Mountai's avatar
Thunder_Mountai
Explorer II
Aug 19, 2015
Help with Cummins Onan Marquis Gold altitude problems
I'm trying to help a friend who is not an Internet/Forum kind of person. He has a Cummins Onan Marquis Gold gas generator model 55HGJAB-6755K. We live at 8200 feet, and he regularly camps between 9-10K feet. The generator has always had hot starting problems at altitude. He had it serviced under warranty a couple of times. He finally talked with someone at Cummins in Henderson, Colorado who knew what they were talking about.
The fix involves replacing the sealed factory carb with a new high altitude carb part #A040N099 at $368. After he replaces the carb, it will run great at 9K feet but ****py at 2K feet. The Onan guy said if he went to sea level and wanted to use the generator, he would have to switch back to the original carb.
Questions for you: Has anyone hacked the original factory sealed carb and rejected it? How involved is replacing the factory carb with the high altitude carb? Is it a do-it-yourself thing?
Other suggestions and comments are welcome.
1 Reply
  • There is an adjustment knob for altitude on the ONAN carb but I don't think it goes up to 8K. Does his have the adjustment knob and has he turned it up all the way?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
