dpgllg's avatar
dpgllg
Help with Dometic AC interior cover
Hello,
I removed the interior AC cover to clean the filter and now can't get it to go all the way back into place. Can anyone tell me if there is some sort of trick etc. to get the cover to slide all the way into position?
Thanks!
Dave
  • Farmboy666 wrote:
    Obviously not upside down, looks does it slide all the way out or just a little and then down. maybe try taking filter back out and try again, it can't be much keeping it out.
    OP here,
    No it is not upside down. The filter can only be placed one way in cover as there are tabs and grooves that hold it in place.
    The cover was taken off by inserting a flat screwdriver into slots that can be seen where gap is. Once this was "popped" it just slid back and off. There are grooves or channels that the curved part of the cover slid into to hold it flush against the cover. I just can't seem to "pop" it back into position.
    Dave
  • Obviously not upside down, looks does it slide all the way out or just a little and then down. maybe try taking filter back out and try again, it can't be much keeping it out.
