fairlaniac
Nov 12, 2018Explorer
Dusty R wrote:fairlaniac wrote:
On the way home I had a thought. I should have removed one of the block off discs to verify air is pushing from the unit. That thought came after 2 hours of driving:)
Those block off discs, are knock out plugs, and once removed will not stay back in.
Be very careful what you use to push down a duct as it is quite likely you could poke a hole in it.
Dusty
Actually the plugs are discs that have an indexing tab and twist to lock.
That is my concern about poking in the duct work. I assume to access the duct work you must pull up the floor? Lets not go there yet :D
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
