Community Alumni
Nov 12, 2018Not applicable
You should be able to remove the floor registers and run the scope thru the duck work that way. You would not need to tear out the floor as the duckwork is below the floor and should be accessible from under the trailer.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
