speediq99
Mar 22, 2022Explorer II
I was told that because the 2022 Ram 3500 doesn't have a fuel cap, fuel spills out even with the check valve in place. I don't see how but apparently it does.
It sounds like the mechanized ball valve may be an overkill. Perhaps a simpler solenoid would work better. It will be nice to leave the manual shutoff valve open, use the solenoid to control the aux tank remotely and let the check valve keep main tank from overflowing. I am just a little confused with the no gas cap situation and what it means.
MC
MC
Grit dog wrote:
All you need is the tee for the fuel filler hose with a check valve in it. They’re sold by the fuel tank mfgs as “kits.” Gravity feed, 100% hands off and super simple.
