speediq99
Mar 23, 2022Explorer II
Here is what my research and feedback is leading.
Use the RDS kit. It comes with a manual shutoff valve for the tank and a check valve for the fuel filler hose.
RDS recommended using a Diesel and Def cap designed for the new Rams.
Diesel Def Cap link
On long drives, leave the manual shutoff valve open.
I am still undecided on the solenoid. Too many complaints on failures. If I use it, I will install it before the RDS kit and after the manual shutoff valve in the tank. I guess the worst that could happen is that it stays closed and I don't get to use the aux tank. The other scenario of it staying open can always be managed with either the check valve or shutoff valve.
Anything I am missing?
Thank you for the feedback
MC
Diesel Def Cap link
MC
