speediq99
Mar 22, 2022Explorer II
Help with fuel transfer valve
Hello,
I just bought an RDS tank. It is gravity filled. It will go in a 2022 Ram 3500. Apparently,RAM decided not to put a gas cap on these trucks so you have to manually fill the tank (open valve) and close it when gauge is full. It sounds like a pain in the neck.
I was told a motorized ball valve could be installed to control the filling of the tank from inside so I don't have to manually and physically pull over to start and stop.
Can you share how you solved this problem?
Thank you
MC
Thank you
MC
 and paste the link there, add any text you wish.  Long URLs cause the forum to skew wide off the screen. Thanks.
