scottsnider's avatar
scottsnider
Explorer II
Dec 02, 2017
Help with gas line question
I am in the process of changing my stove/oven to just a stove top, as I was connecting the gas lines I smelled Gas. Yes shut off, then got a gas sniffer and it seems the gas hose has a leak not the metal parts. So how would you tell me the best way to fix it? Its about 6 or 7 inches from the metal parts the bring the gas to the stove top. Do I get some more hose and some fittings to cut and reconnect because its also on a curve area. Or what??????
❚ Did you miss the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic.
    Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
  • Thank you Rhagfo, I have a handy man friend that had done stuff like this before so he will help me.
  • rhagfo's avatar
    rhagfo
    Explorer III
    scottsnider wrote:
    Rhagfo, its rubber.
    Well like I stated in our 5er all connections are made with soft copper with flared fittings.
    If you have a rubber line I would strongly suggest taking to your local propane dealer and have a replacement made. I have done this with pigtails and other propane hoes and the cost is reasonable.
  • rhagfo's avatar
    rhagfo
    Explorer III
    Is the line you are referring to copper or rubber. all of our gas connections inside the RV are flared soft copper tubing.
  • Go to a propane dealer and buy a new hose. Unless you have the proper tools there is no way for a DIYer to repair them.
Having RV issues? Connect with others who have been in your shoes.24,358 PostsLatest Activity: Feb 08, 2026
