74vette
Jan 01, 2016Explorer
Thanks Joe417
You are right, it is the flange that is pushed then glue into the tank. I have asked many RV repair people with no answer other than put it back with the flange glued with butyl into the tank. That is what I am going to do today as I need to get on the road. I have a hole cut in the belly plastic cardboard so I can moniter the fix. Will put the pan back without the insulation as I need to make sure it is correctly repaired first.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
