Joe417
Jan 01, 2016Explorer
There is no pressure except gravity on the tank, butyl should seal it provided you can get the clamp tight without pushing the valve out.
I found this on the HOBIE web site:
"It's hard to find glues to use on Polyethylene. Here's a list starter for things that work and those that don't.
Glues that work:
-- Scotch Weld DP 8010 by 3 M
-- Scotch Weld DP 8010 NS (same epoxy but with fillers)
Outstanding bonding. These glues are not the easiest to find, and not cheap. Price for small container is about $20; available through some R.S. Hughes, Graingers, Fastenal, and perhaps other industrial suppliers.
Tip: you can save the added expense of an applicator and dispenser if you're willing to push it out of the unequal cylinders and mix it. Five minute working time.
Glues that don't stick: (so far)
-- JB Weld
-- Super Glue epoxies (all -- verified w/ manufacturer)
-- Gorilla Glue (according to manufacturer -- didn't try it personally)
-- PVC glue, even w/ primer
Let us know if it works.
Glues that work:
-- JB Weld
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
