NorthernMarshPa
Aug 09, 2022Explorer
Excellent points about low miles not always being a plus. So much to consider!!
Yes! We were looking into this when we got serious about the majestic. Only got a quote from one company, but check out the prices they quoted us:
It would be more than $1000 to get everything inspected. It's less to get an actual house inspection! Do you think it's really possible to do one for a couple hundred $?
Ah this is a whole other story. We initially planned to tow a small trailer with our 2007 Toyota Highlander (3000 lbs towing capacity), which is in pretty great shape, EXCEPT: the undercarriage is incredibly rusty. Visited a few trailer hitch places and a mechanic, all of them said that there's too much rust for a hitch... Called around to autobody shops and talked about reinforcing the frame... Started to sound complicated, which is when we switched to searching for a motorhome. Now we're back to wondering if we should look into reinforcing the undercarriage or buying a different used vehicle + trailer... We just want to get on the road while there's some summer left, but it's looking more complicated than we ever realized. On top of that, we've been hearing that starlink RV might not be as reliable as we hoped, so I don't know where this dream of living & working on the road is heading.
valhalla360 wrote:
call up an independent mobile RV tech and see if they will to an inspection for a couple hundred bucks and walk you thru the issues. Then when you find what you think is a good deal, make an offer contingent upon an independent inspection.
rvproseal.com wrote:
- Virtual consultation (images): $199 plus tax.
- Leak detection and water damage inspection: $479 plus tax
- Water damage only inspection: $340 plus tax
- Additional Pre purchase inspection of the following each priced at $240 plus tax: Appliances & Life Safety, Fresh water system, Electrical system
Gdetrailer wrote:
If you have a vehicle with enough towing capacity you could consider looking at a small travel trailer. A bit less convenient than a motor home but also a much less costly way to start RV'n..
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
