Gdetrailer
Aug 09, 2022Explorer III
IAMICHABOD wrote:
You have been given some pretty good answers and advice so far.The one thing that always seem to come up when talking about a Former Rental is the old wives tale of "drive it like ya stole it" and many other flat out wrong statements and misleading information.
Remember that when you rent a RV you sign a contract that says you are liable for any damages and also a $1000 deposit.
Also they have to be maintained and documented to stay on the road,thus making money.
"Driving like you stole it" is a metaphor for folks rent it, but may not take kid glove care of it.
There are "good" renters, but there are far more "not so good" renters.. It is the "not so good" renters that treat things like garbage.
A former coworker had once got a rental car because his was in the shop for some repairs.. Several of his stories driving that rental car at high speed then slamming the emergency brakes on to get a nice cool side ways spins gave me grey hairs and I wasn't with him when he done it.
There are thousands of things that can be broken or damaged on a motor home that may not ever show up for yrs.
You bring up a valid point, RV rental companies are in to make money.. The only way they can truly make money is to not put any more money into the unit than the bare necessity.
To maximize the return of profits on the cost of keeping that RV "on the road" they are only going to fix the obvious things that need fixed.. Things like, lights, brake pads, tires and oil changes.. They are not going to do a thousand point inspection, or fully rehab the unit. When they have to start to make major and costly parts repairs they are going to dump the unit..
The unit the OP was looking at with 160K miles is most likely over due for front end parts like tie rods and upper and lower ball joints. Very critical parts that "keep you on the road".. Rebuilding that front end properly you are looking at a min of $2K right off the top..
Next stop is brakes, calipers do get stuck and freeze up at 160K miles that is well above normal life of those.. Yet another $1500 if you pay a shop to replace those.. Of coarse it doesn't stop there, good chance the brake hoses are in need of replacing.. Stack another $500 for parts and labor.. Pads and rotors, yeah, bet those are done.. Pony up $150 per rotor, $160 for front and back pads.. We haven't even scratched the surface of possible worn out parts and we are now up to $4,260..
Engine, $5,000-$8,000 for short block plus RR labor..
Transmission, $4,000 rebuild plus RR labor..
Rear end, yeah $2,000 would not be out of line if you had to have a mechanic dive into it..
Then we haven't even addressed all of the delamination in the OPs pictures, it HAS severe water damage in the corners, it HAS severe water damage below the windows, it HAS severe water damage under pretty much every item that goes through the walls to the outside. The rental company obviously didn't do anything like "maintenance" to prevent the water damage.. Things like removing windows and trim and refreshing the caulking periodically was clearly not done by the rental company.. What else did they not attend to??
Speaking of mechanics, ever try to find a mechanic that is willing or able to work on a motor home? They are pretty scarce and the ones that do are up to their armpits in work already.. Very few dealerships are equipped for motor homes and small garages may not have the space to fit a motor home.
While it may be possible to find a "gem" in used rentals the odds are better your going to end up with "cubic Zirconia" (IE "glass") instead of a "diamond".
The fellow attempting to sell the motor home the OP was considering obviously decided that the one they are selling is not what was represented or as good as represented when they bought it.. Otherwise they wouldn't be selling it..
If you like your used rental, that is fine, but the one the OP posted the pictures of is too expensive, too many miles, too much neglect and water damage and we haven't even seen the results of the damage inside.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
