donn0128
Jun 10, 2013Explorer II
There should be two carriage bolts holding it in place. Take them out and if necessary pry the clamps apart just a bit. The outer tube has a couple of upset places that locate it. Be sure to place a hydraulic jack under the frame so it does not collapse. The leg then comes out the top once you remove everything below. The inner most tube will fall out the bottom. It is very easy to do, but the assembly weighs about 30 pounds so be prepared for the weight. Take the motor and gear box off first to help reduce weight. All it takes is a philips screwdriver and I believe a 1/2 or 9/16 wrench.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
