donn0128
Jun 11, 2013Explorer II
Take the cap off. You will see a bevel gear facing on end. Tap the pin out and tap the shaft out of the housing. The gear below is sitting on a pin so all you need to do is lift it out, then with a pair of pliers remove that pin. Then with a soft hammer tap the shaft out the bottom of the leg. There is a cross piece that sits in a slot that acts as a guide for the top of the shaft. That also comes out easily. Now you have the screw and nut in your hands. I suspect you will find it cheaper to buy a complete new leg assembly direct from Venture Mfg. They will need the P/N and serial number from the metal cap at the top of the leg.
BT,DT. I just rebuilt my left leg as well. Just enough years and it was finally done. Luckily I had parts from my dual motor conversion project so it was only a matter of swapping parts from one leg to the other.
While your at it, and if your planning to keep this fiver for a while I would suggest the dual motor conversion and adding up limit switches to prevent jamming the legs and tearing up the gear box.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
