- BFL13Explorer IIWhat exactly do you mean by "bonded" ? In Rvs the main dist panel for the 120v breakers is not bonded. The shore power source panel the pedestal receptacles are on is the bonded one.
So your sub-panel from the inverter needs to be carefully defined as to what you are doing. - larry_cadExplorer II"boned"???
Or did you mean "bonded"??
If you mean bonded, then the answer is no!! NEC specifies a "sub panel" is to have isolated neutral bus bar, carried back to the main panel.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
