wa8yxm
Jun 21, 2023Explorer III
When the generator stops normally the indicator light blinks a pattern
Like 3-3-2 3-3-2 3-3-2 (the pattern is usually longer) Write it down and post it
Then we have a clue
Some things that can cause that
Dirty slip rings
Bad oil pressure sensor
Other bad sensors
Bad control board (The parts that read the sensors)
and so on.
But with the code we get a clue.
Dirt slip rings often report as "Cranking speed too slow or low battery" by the way.
Then we have a clue
Dirty slip rings
Other bad sensors
and so on.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
