russkerri
Jun 07, 2015Explorer
Old-Biscuit wrote:dougrainer wrote:Old-Biscuit wrote:Chris Bryant wrote:
I have the service manual for that at http://bryantrv.com/docs2/docs/n300.pdf- it gives specific steps for troubleshooting- the first and easiest thing would be vacuum out the burner- make sure it is clean. Just a vacuum through the burner access door would help.
There you go.......specific info for your model
We do NOT need specific info for the OP's question. He stated he had the Green needle meter refer and what we posted is spot on for how ANY of the meter refers operate. The needle will stay in the GREEN regardless if the flame stays lit as it should. Even in bypass mode. IF the needle goes down off the green the LP flame has failed. Doug
OP needs it so HE can further troubleshoot..unless you are making a 'mobile call'
Actually, the OP is a SHE...just for the record. The service manual is helpful and when we have time, we will appreciate having it available for troubleshooting. However, my original post really wasn't asking how to fix it, I was simply asking whether or not the meter was an indicator of whether the fridge is operating on propane.
