russkerri
Jun 07, 2015Explorer
dougrainer wrote:Old-Biscuit wrote:Chris Bryant wrote:
I have the service manual for that at http://bryantrv.com/docs2/docs/n300.pdf- it gives specific steps for troubleshooting- the first and easiest thing would be vacuum out the burner- make sure it is clean. Just a vacuum through the burner access door would help.
There you go.......specific info for your model
We do NOT need specific info for the OP's question. He stated he had the Green needle meter refer and what we posted is spot on for how ANY of the meter refers operate. The needle will stay in the GREEN regardless if the flame stays lit as it should. Even in bypass mode. IF the needle goes down off the green the LP flame has failed. Doug
Thank you, Doug. That answers my question as succinctly as the question was intended. As you said, I wasn't trying to get anyone to fix my problem, I was really trying to easily determine IF we have a problem since the owner's manual did not clearly explain what should happen after the propane is lit. We are on our first big trip with our travel trailer and have lots of little details to attend to and things to learn. Thanks, Kerri
