pianotuna
Oct 29, 2018Nomad III
If you can get to 80 amp-hours of recharging per day, that works out to just 960 watt-hours.
The fridge running on propane may use about 1/3 of that.
If you go with just 200 watts of panels then the maximum harvest under totally perfect conditions would be 800 watt-hours. I do not think that is likely.
500 watt hours (after the fridge consumption) means being ultra careful with power use.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
