Stromboli's avatar
Stromboli
Help with picking out components, and do I need solar.
Do I need solar?
I’m up grading and setting up the trailer for long term dry camping.
I’m installing a Honda 3000i generator onto the tongue of my Nash 17K.
I’ve also decided to add lithium batteries to replace the dead lead acid batteries that the trailer came with, probably 2 Battle Born 100Ah 12V LiFePO4.
That much I’ve figured out.
Now the hard part.
I have the opportunity to do it all right now. Generator, solar panels, inverter, duel transfer switches, new charger, solar controller. But I’m so confused with picking out the rest of the components.
My neighbor has agreed to do all the work for me and he is very capable.
There is not a lot of room on the roof of the 17K.
Is it worth it to add 200 watts of solar?
Would 200 watts keep me from running my generator so often?
What other components should I buy?
I’ve looked at different kits on Amazon but don’t know if the quality is there and which brands to buy.
I’ve had my coffee and my brain still hurts.
Any advice would be appreciated.
  • Hi,
    It is likely that 200 watts is not enough.
    I'd go with 5 to 6 hundred watts.
  • you need to determine what your loads will be, how much power your going to use is going to determine if solar will even be a benefit at 200w
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
