time2roll
Mar 30, 2015Nomad
https://www.solarblvd.com/product_info.php?cPath=1_272&products_id=2869
Trouble with plug and play kit is that it is never quite how you would like to have.
Above kit could use a better controller and longer wire.
Beware of kits where the controller is attached to the panel as you can get too much voltage drop between the controller and battery. Controller should be separate and mounted close to the battery. Longer wire to the panels is not such a big deal.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
