MrWizard
Oct 04, 2016Moderator
the bottom button the AH button, pushing this one cycles thru the the display
differernt little LEDs on the right hand side will be on indicating which mode is being displayed
AMPS rate of charge or discharge ... LED 'A'
Amp hours , shows present amphr count, goes down if discharging
goes up, when charging, will stop counting when it hits your 230 preset... LED 'AH'
Percent AKA SOC gives you a 3 digit number like 87.2 LED '%' will be on
look at this video, i cycle it thru the display modes
batteries are at 608 AH 90% SOC down 66ah from the 674ah set point
using about 21amps discharge
there is a CHARGE LED above the amps led, the charge LED lights when you are charging, not on and the amps reading is discharge/use
there is NO plus or minus sign
http://vid298.photobucket.com/albums/mm251/Mr__Wizard/20160817_234329_zpsfd3htmvx.mp4
you can watch how much you are taking out
or set it on percent, and when you see it get to a certain level like 75% or 50% do a recharge
it varies depending on your style of camping
the first day you might want to go about your normal USE routine, and then check the ah count and percent numbers before the recharge ?
we are heavy users and recharge every day, but you may not need to
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
