BFL13
Feb 27, 2020Explorer II
You could choose to by-pass the isolator and always have the house to engine batts in parallel even when engine is off. Or you could have a manual disconnect instead of that isolator. One way would be a fuse in a holder. Pull the fuse as your way to disconnect.
Pros and cons for leaving them in parallel. One pro is if parked for long your solar can keep the engine battery up too without having a separate charger for that.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
