Chum_lee
Feb 28, 2020Explorer
Just a question. Where does this 300 amps (charging) come from for continuous use? Very few automotive type alternators will produce 300 amps, (@14 volts) continuous, for battery charging purposes. IME, when solenoids/relays regularly fail, it's because they get too hot. That can be a result of small wire size on the signal circuit, or, too much resistance on the main load (switched/charging) circuit.
When you say the solenoid is warm, . . . . . how warm is it? Too hot to touch?
Chum lee
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
