mchero
Feb 28, 2020Explorer
Thanks for the reply Mex. Hope you get back to a laptop shortly.
Batteries 3 and 4 were not fully charged. The cable between them was replaced (Positive posts in upper right). I'm planning to remove the negative cable on battery 3, that should isolate 3 and 4 from the bank. Then I will either charge 3 and 4 individually (6v) or as a pair (12v).
I'll use the 5 amp charger posted below.
Noco 5 amp
200 amp shunt is for my Midnight Solar Classic WizBangJr.
Thoughts/Suggestions?
Noco 5 amp
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
