MEXICOWANDERER
Mar 05, 2020Explorer
Any
Any
Any
Charger that can reach 16 volts while meeting 5% amperage
Light bulbs hooked in parallel if necessary to allow correct current to pass
100 watt 12 volt bulb will allow close enough to 9 amps constant current
50 watts will allow 4 amps to flow...
Enter screw-in regular lightbulb with positive from battery
Exit the other base screw and continue on to battery positive.
Negative is connected direct from battery minus ground.
By paralleling 100 and/or 50 watt bulbs you can make a CURRENT regulator. Constant current.
Test
If 2 100 watt and one fifty watt bulb are connected in PARALLEL how many amps will flow at 16 volts
OK. Now what size battery bank in amp hours 5% would these three bulbs in parallel be ideal for.???
These bulbs are available online or at NAPA parts stores. You may have to order the bulbs. Plastic or ceramic bases are available at Hardware Stores.
Any
Any
Test
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
