CARBONE's avatar
CARBONE
HEX KEY
Hi Alll
Just got a 2001 Winnebago adventurer 32v, Class A cant find the hex key hex key to open the Eng cover, any help on what size it is
Thanks
EM alfredcarbone@gmail.com
AAL
  • CARBONE wrote:
    oddupton
    WHAT SIZE ???????
    It was answered two days ago in your other thread.
  • It should be a 5/16".
    You can take a standard L shaped wrench and turn it into a nice T handle wrench. Take a 5" piece of 1/2" PVC pipe and drill a hole in the middle of the pipe on one side. Epoxy the short side of the Allen wrench into the pipe using epoxy putty. Loctite makes a very easy to use epoxy putty that you just cut off a chunk, kneed it together, and mush it into place. Available at Walmart, Lowes, and others.
    good luck-- Mick
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
