MEXICOWANDERER's avatar
Jun 11, 2016
Hey Jim in Denver! (Megawatt)
A few months ago you reported that your Megawatt Stopped Working when trying to charge several 8-D batteries...
Whatever happened? Did you get it fixed? Return it for credit? Let it sit on a shelf?
  • JiminDenver wrote:
    JiminDenver wrote:
    Looks like a tear down of a 24v megawatt.
    click
    could be the clone
    Link goes nowhere
  • Will research better bipolar transistors if available lower ESR caps and detail the weakness in the trident printed circuits leading to the 6 output terminal block. Genuine SILVER heatsink compound however is a must between discrete and block then block to case. Whatever it takes to remove heat away from those P/N junctions.
  • Megawatt 24 volt? News to me. The cheapowatt and Meanwell both have a different circuit layout never mind part numbers. Be cautious.
  • MEXICOWANDERER wrote:
    A little bit of work but I'll try. I sure like silver based thermal grease. I'll need to shop eBray for links and wipe the camera lens. YES NINER! PANORAMIC VIEW! :)
    Good boy! Do not shoot pictures with camera looking straight down on the subject... there are gps and gravity sensors in that camera, they have to know what is up or down, doesn't work if you take pics from directly above the subject matter.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
