- NinerBikesExplorer
MEXICOWANDERER wrote:
A little bit of work but I'll try. I sure like silver based thermal grease. I'll need to shop eBray for links and wipe the camera lens. YES NINER! PANORAMIC VIEW! :)
Good boy! Do not shoot pictures with camera looking straight down on the subject... there are gps and gravity sensors in that camera, they have to know what is up or down, doesn't work if you take pics from directly above the subject matter. - MEXICOWANDERERExplorerMegawatt 24 volt? News to me. The cheapowatt and Meanwell both have a different circuit layout never mind part numbers. Be cautious.
- MEXICOWANDERERExplorerWill research better bipolar transistors if available lower ESR caps and detail the weakness in the trident printed circuits leading to the 6 output terminal block. Genuine SILVER heatsink compound however is a must between discrete and block then block to case. Whatever it takes to remove heat away from those P/N junctions.
- JiminDenverExplorer IIworks now
- MEXICOWANDERERExplorerThis is a very good thermal compound...
http://www.ebay.com/itm/2-PCS-3g-GD900-1-Containing-Silver-Heat-Sink-Compound-Thermal-Grease-Paste-BX3-/261719739827?hash=item3cefb64db3:g:Kr8AAOSw7ThUlomN
Scroll down the page. Links to many products. Double check to insure what you choose says "Silver". Syringe, tube, can, etc. Too much is far better than too little. - MEXICOWANDERERExplorerA little bit of work but I'll try. I sure like silver based thermal grease. I'll need to shop eBray for links and wipe the camera lens. YES NINER! PANORAMIC VIEW! :)
- Vixen21ExplorerRemember: For the others that bought Megawatt's, a tutorial with pictures and part numbers/links are worth thousands of words.....and save a whole lot of head scratching....
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
