Rmack1
Mar 11, 2016Explorer
Bumpyroad wrote:
I'd look into prying up the floor of that cabinet to see where the wires lead and how you can fix situation. you can always put another thin bottom board into that cabinet to cover the hole you make. if you can't pry it at all, just cut a hole in the floor directly above the lamp mounting area.
are there multiple switches that control that light? perhaps bad switch?
bumpy
Wow. I'd have to grit my teeth to tear up that nice cherry wood cabinetry. I was going to take off the CD player/radio and see if I could get at the wires where the splice might be failing. Going to be challenging, because the flat screen TV is mounted right in the way. Oh well, good thing I'm retired!
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
