Sandy___Shirley
May 05, 2015Explorer
ScottG wrote:YamaDooed wrote:
That hose connects to the regulated or low pressure side of the propane line on the trailer... You will also need to remove the regulator on the grill to make it function correctly...
Exactly, the line that runs under your trailer is after the regulator at the tank so they are low pressure.
This is a motor home. It does not have external tanks, so I'm not sure if the outlet is after a regulator or not. Have to check the specs if I can find them
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
