MrWizard
Dec 18, 2014Moderator
assuming your thinking of heavy arcing ?
how often do you intend to actually use the switch, for what purpose
to occasionally disconnect the solar panels from the controller
if this is only going to happen for maintance
and will normally be closed aka ON most of the time
just get a normal 20amp 120v spst toggle, they even make 20amp LIGHT switchs for wall plates.. no need to worry about a special DC switch, if its not going to be switched on-off every day
