CA_Traveler
Dec 19, 2014Explorer III
DrewE - Interesting DC disconnect switch and certainly a good price. I briefly read about their mechanical/hydraulic operated CBs. Maybe a latching solenoid which would have no draw if one was available...
Wiz - Yes arching is the issue with DC. I agree that a AC switch can be used but was surprised with the limited selection of DC rated switches for higher voltage at reasonable prices. In fact I have wired in a cheap 2 pole A/C disconnect switch for both of the panel wires but ideally would like a better quality switch. I'll be turning off the controller about 10 times/year for maintenance and for covered rig storage with no power and full battery disconnects.
atreis - I have a friend that uses one of these on 4 panels connected series/parallel about 60VDC. I suspect that switch is rated for 48VDC.
YC1 - Both actually. 3 series wired panels at over 100VDC and 8A+ connected to a MS MPPT 60 solar controller with 12V batteries. There is a remote possibility of adding another panel with series/parallel wiring for 70VDC at 17A. Due to the high voltage and lack of ground reference I'd also prefer a 2 pole switch.
The controller and related wiring is installed. Solar panels soon.
I did get some offline input from another poster which helped expand my search. And thanks to everyone.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jun 08, 2019
