RasMouSein
Jun 04, 2017Explorer
time2roll wrote:RasMouSein wrote:You mean they pulled #10 negative back to the battery?
The #10 it's like 30' run, so 60' total, a Voltage drop calculator says at 14 amp, from 13 volt should have a 1.7v drop..
Consider a direct frame connection close to the motor with some of that bonding paste.
From the switch to motor, the wire change polarity depending if going forward or reverse, so definitely no bounding to frame.
As far as Battery connection to converter I upgraded with #4 8"long positive and negative.
The slide use the only 30amp fuse at the bottom.
Click For Full-Size Image.
Here is the new setup for battery and busbar for later expension
It can be seen the #4 going to the right,
and the bound going trough the floor.
Here the motor, and the #4 going behind it, that I could tap into.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
