KMLsquared's avatar
KMLsquared
Higher voltage solar panels?
If I could get a 56v. 310 watt panel for free is there any MPPT charge controllers that will step that down for me? I'm having a hard time googling one. If so is there any downside to using a panel with that high of voltage?
Thanks in advance.
  • Actually a high voltage panel with an MPPT controller works very well. We find it produces usable current when a "12V panel" produces nothing. We have a 185W hooked up to a Morningstar MPPT Sunsaver.
  • yoosmart
    I recommend the BN series, as they are fully adjustable. I just bought the 3215BN with remote. Can't speak to it's reliability, yet, but hey, why should I be the only guinea pig?
    3215BN w remote
    2215BN
  • West
    I thing the clipping by a MS 15 would be considerable but a 20a MPPT controller that could handle the voltage would probably not see that much clipping in a flat mounted panel. I think the Rogue 20a MPPT is $250 and the Tracers are less than that.
  • Get it for free? Go for it. The Rogue 30a, Morningstar 30a, the Midnight Kid 30a MPPT controllers would all handle it. They run between $300 and $400 but those panels are not cheap either. You should see 20-25a from the combo.
  • Hi BFL13,
    Those small inverters are all grid tied. Not too useful for an RV.
  • Is 56v a "48v" panel? Some, not many, controllers will do 48-12 to a 12v battery.
    Advantage low amps on the panel to controller wire path, so the wires can be thin. Disadvantage, the lower efficiency bucking from 48-12 in the controller.
    With the panel free it is all math to see if the controller cost makes the whole set-up "worth it"
    Stick houses use 48v and there are now small but useful 48v inverters they get for them. Don't know a lot about it--might be useful in an RV?
  • Hi,
    Make sure there is shade free room on the roof for the panel.
    Tristar MPPT 30 amp unit would be a nice fit.
  • Check out the Outback brand of controller. The only downside is having to buy a more expensive controller.
    I run twice that voltage with my 60a controller.
  • 15 amp SunSaver would work but would clip power to 15 amps. $200
    TS-MPPT-30 would give full power but cost is about $350.
    I will let the others list the low price options.
