maillemaker's avatar
maillemaker
Hobbs hour meter replacement?
Hi. I finally got around to pulling the range cover so I could pull the old Hobbs hour meter that quit working some time ago.
I can't quite make out the part number or the volts on the back of the unit. It looks like 15000 K/6 4-10 VDC
Most replacement hour meters I have seen are like 12-60 VDC.
What should I look for for a replacement for this guy?
Thanks,
Steve
  • ALL RV Hourmeter's for the Gensets run on 12 volts. Doug
    PS.that is not a 10, but either a 60 or 80 volt.
  • What's it for--an Onan generator? If so, I think they run off of a (nominally) 12V supply. You could always take a voltmeter and measure the voltage at the hourmeter connection since you have it accessible.
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
