images
Aug 12, 2015Explorer
Holding Tank Flush System
I bought a flush system to install in the holding tanks of our new trailer, upon inspection I found that the tanks (40 gal) are long, wide,shallow and there is absolutely no place to install a flusher other than the bottom.
The tanks run from I-beam to I-beam, and on each side is a a metal support running the entire length of the tank leaving no more than 1 3/8" uncovered on the top, the depth of the tank is about 5".
I hesitate to drill into the bottom of the tank for obvious reasons, if I could get to the inside of the tank it would be no problem to install fittings but that is not a option.
With a tank like this the wand down the toilet wouldn't even work efficiently.
Has anyone found a way around this issue?
Thanks in advance.
Joe
Thanks in advance.
Joe
