Erie_Tom
Jun 04, 2014Explorer
last year in the high heat I started to get false reading of 3/4 full.
Flushed tank out with the Hydro flow fitting on the dump hose. It is a right angle with a hose water hose attachment. Then added the enzyme solution for the black water. Filled it with a third tank of water and drove 5 hours to the next campground and dumped. No more problem.
The sensors get coated and give the false reading. Try this before you drill holes or try to remove sensors.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
