calstar's avatar
calstar
Holding tank monitor panel replacement
I have a 1996 Lance 3000, needs a new holding tank monitor panel. The stock panel is a KIB pcbk4, is there a direct replacement? I've googled this but haven't found any direct replacement information, but I did find that KIB does not make publicits wiring diagrams or much if any information on its products. I will contact KIB but asking for input here first.
thanks, Brian
  • Most of the time, when it might appear that the "panel" is not working anymore, that is NOT because of the panel itself but because the sensors in the tanks have gone bad.
  • DrewE's avatar
    DrewE
    Explorer III
    The KIB panels are all mostly pretty similar electrically and not too complex or hard to reverse engineer. I suspect most any of them that have similar features could serve as a replacement for yours, though it may take a tiny bit of work to connect the wires to the right terminals.
    (The circuit, for the little three/four/five light units, basically consists of a quad comparator that compares the input voltage signal against a series of voltages derived from a resistor chain. If there are switches for other things such as the water heater or pump, they are entirely independent electrically.)
  • Google,
    seelevel rv tank monitor.
    This is a whole new monitor system that is rather easy to install and to me is better than what comes on new in new rv's.
    Dusty
  • Google,
    Dusty
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
