DrewE
Feb 13, 2020Explorer III
The KIB panels are all mostly pretty similar electrically and not too complex or hard to reverse engineer. I suspect most any of them that have similar features could serve as a replacement for yours, though it may take a tiny bit of work to connect the wires to the right terminals.
(The circuit, for the little three/four/five light units, basically consists of a quad comparator that compares the input voltage signal against a series of voltages derived from a resistor chain. If there are switches for other things such as the water heater or pump, they are entirely independent electrically.)
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
