CAJW
Jun 04, 2014Explorer
I'll try the rock salt and/or ice cubes method, but oddly enough, the issue is with the fresh and gray water monitors. AFAIK, the black tank monitor is working properly. Also, as luck would have it, the only tank monitor wiring that is accessible, without removing the belly panel or cutting access panels, is the black tank. Unit is only a year old so I'm a bit surprised that the fresh water especially is acting up already. We've got very good water (low in minerals, almost soft) where I live and have only filled the tank once from an alternate source which was months before the monitor went kaput.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
