64thunderbolt
Dec 09, 2014Explorer II
Ron3rd wrote:CAJW wrote:
I'll try the rock salt and/or ice cubes method, but oddly enough, the issue is with the fresh and gray water monitors. AFAIK, the black tank monitor is working properly. Also, as luck would have it, the only tank monitor wiring that is accessible, without removing the belly panel or cutting access panels, is the black tank. Unit is only a year old so I'm a bit surprised that the fresh water especially is acting up already. We've got very good water (low in minerals, almost soft) where I live and have only filled the tank once from an alternate source which was months before the monitor went kaput.
I would not add rock salt to any tank. Highly corrosive and can damage the retaining bolts on the dump valves. Rock salt is the last thing I would add to a holding tank.
If water gets to the bolts the orings are leaking.
