westend
Jun 16, 2015Explorer
I would suggest to check the white wire for continuity to ground. You could then measure resistance from the other individual wires to the ground wire. While you're about that, you may wish to power a turn signal and see if there is voltage on any of the colored wires. It is almost too much of a coincidence that the mfg would use a trailer harness standard for tank wiring.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
